Zum Hauptinhalt wechseln
Vtech InnoTab 3S Camera Replacement
Was du brauchst
    1. Vtech InnoTab 3S Camera Replacement, Rear Panel: Schritt 1, Bild 1 von 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: Schritt 1, Bild 2 von 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: Schritt 1, Bild 3 von 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      Frag FixBot
      Kommentar hinzufügen
    2. Vtech InnoTab 3S Camera Replacement: Schritt 2, Bild 1 von 2 Vtech InnoTab 3S Camera Replacement: Schritt 2, Bild 2 von 2
      • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
      Frag FixBot
    3. Vtech InnoTab 3S Camera Replacement: Schritt 3, Bild 1 von 3 Vtech InnoTab 3S Camera Replacement: Schritt 3, Bild 2 von 3 Vtech InnoTab 3S Camera Replacement: Schritt 3, Bild 3 von 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
      • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
      • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
      Frag FixBot
    4. Vtech InnoTab 3S Camera Replacement: Schritt 4, Bild 1 von 1
      • Carefully remove the rear panel from the front panel of the device.
      • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
      Frag FixBot
    1. Vtech InnoTab 3S Camera Replacement, Camera: Schritt 5, Bild 1 von 2 Vtech InnoTab 3S Camera Replacement, Camera: Schritt 5, Bild 2 von 2
      • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
      • The connection between the motherboard and the camera is located at the near the top of the device.
      • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
      • Carefully lower the latch until you hear a click to secure the new camera to the device.
      • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 8-2, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Mitglieder
9 Anleitungen geschrieben
4 Kommentare zur Anleitung
Where do you get the replacement camera? I can't find them online.
rongennero - Antwort Teilen
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - Antwort Teilen
Where can i buy the camera?
Stephan Meyer - Antwort Teilen
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 2,377
