Zum Hauptinhalt wechseln
WRS315SDHW Refrigerator Thermistor Replacement
Was du brauchst
  1. WRS315SDHW Refrigerator Thermistor Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: Schritt 2, Bild 1 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: Schritt 2, Bild 2 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: Schritt 3, Bild 1 von 2 WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: Schritt 3, Bild 2 von 2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly (shown with the assembly removed).
  4. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: Schritt 4, Bild 1 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: Schritt 4, Bild 2 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: Schritt 4, Bild 3 von 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: Schritt 5, Bild 1 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: Schritt 5, Bild 2 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: Schritt 5, Bild 3 von 3
    • Disconnect the two harness connectors attached to the temperature control board assembly.
  6. WRS315SDHW Refrigerator Thermistor Replacement, Remove the assembly: Schritt 6, Bild 1 von 1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: Schritt 7, Bild 1 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: Schritt 7, Bild 2 von 3 WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: Schritt 7, Bild 3 von 3
    • Pinch and pull the connector attached to the thermistor to disconnect it.
  8. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: Schritt 8, Bild 1 von 2 WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: Schritt 8, Bild 2 von 2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
nicO
15.885 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
545 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 146
