Zum Hauptinhalt wechseln
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
Was du brauchst
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: Schritt 2, Bild 1 von 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: Schritt 3, Bild 1 von 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: Schritt 3, Bild 2 von 2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: Schritt 4, Bild 1 von 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: Schritt 4, Bild 2 von 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: Schritt 4, Bild 3 von 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: Schritt 5, Bild 1 von 1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: Schritt 6, Bild 1 von 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: Schritt 6, Bild 2 von 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: Schritt 6, Bild 3 von 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
Abschluss
Arthur Shi
254.543 Reputation
529 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.410 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 39
Insgesamt: 3,026
