Einleitung
Follow this guide to remove the drive belt for the Wacker Compactor Plate VP1550AW 2014.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
Use scissors or a blade to cut the drive belt.
Remove the drive belt.
Guide the belt over the top of the clutch pulley.
Loop the belt underneath the pulley axle.
Rotate the pulley slowly and guide the built into the groove.
