Zum Hauptinhalt wechseln
Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement
Was du brauchst
  1. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Safety Precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the top panel: Schritt 2, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the top panel: Schritt 2, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the top panel: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    Kaufen
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the top panel: Schritt 3, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the top panel: Schritt 3, Bild 2 von 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 4, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 4, Bild 2 von 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the control panel: Schritt 5, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the control panel: Schritt 5, Bild 2 von 2
    • Disconnect the control panel cable from the main board.
  6. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 6, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the drum light connector.
  7. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the control panel: Schritt 7, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the control panel: Schritt 7, Bild 2 von 2
    • Remove the screws securing the control panel.
  8. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the control panel: Schritt 8, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the control panel: Schritt 8, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the control panel: Schritt 8, Bild 3 von 3
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the door switch: Schritt 9, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the door switch: Schritt 9, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the door switch: Schritt 9, Bild 3 von 3
    • Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
    • Unplug the connector.
  10. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the front panel: Schritt 10, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the front panel: Schritt 10, Bild 2 von 2
    • Remove the upper front panel sheet metal screws.
    • Tilt the machine backwards and prop it securely, or have a friend hold it.
    • Remove the sheet metal screws on the bottom edge of the panel.
  11. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 11, Bild 1 von 1
    • Remove the screws inside the door area below the drum opening.
  12. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the front panel: Schritt 12, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the front panel: Schritt 12, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the front panel: Schritt 12, Bild 3 von 3
    • The panel is heavy and awkward. You may want to have a friend help you with this step.
    • Pull the bottom of the panel away from the chassis about two to three inches.
    • Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
    • Make sure you don't snag the door switch wire harness as you remove the panel.
  13. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the cover plate: Schritt 13, Bild 1 von 1
    • Remove the cover plate screw.
  14. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the cover plate: Schritt 14, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the cover plate: Schritt 14, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the cover plate: Schritt 14, Bild 3 von 3
    • Remove the cover plate.
  15. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the cord: Schritt 15, Bild 1 von 1
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  16. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the cord: Schritt 16, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the cord: Schritt 16, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the cord: Schritt 16, Bild 3 von 3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  17. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the cord terminal block: Schritt 17, Bild 1 von 1
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  18. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Move the cord terminal block: Schritt 18, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Move the cord terminal block: Schritt 18, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Move the cord terminal block: Schritt 18, Bild 3 von 3
    • Move the cord terminal block behind the rear panel.
  19. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the rear panel: Schritt 19, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the rear panel: Schritt 19, Bild 2 von 2
    FixMat
    $36.95
    Kaufen
    • Remove the rear panel screws.
  20. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 20, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 20, Bild 2 von 2
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  21. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the rear panel: Schritt 21, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the rear panel: Schritt 21, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the rear panel: Schritt 21, Bild 3 von 3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  22. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Reassembly information: Schritt 22, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Reassembly information: Schritt 22, Bild 2 von 2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  23. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lint filter: Schritt 23, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lint filter: Schritt 23, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lint filter: Schritt 23, Bild 3 von 3
    • Pull the lint filter up out of the lint filter slot to remove it.
    • These photos show the front panel in place, but the procedure is the same if the front panel is already removed.
  24. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the lint filter housing: Schritt 24, Bild 1 von 1
    • Remove the mounting screws securing the lint filter housing.
  25. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lint filter housing: Schritt 25, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lint filter housing: Schritt 25, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lint filter housing: Schritt 25, Bild 3 von 3
    • Pull the filter housing outward from the chassis and down to remove it.
  26. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the moisture sensor: Schritt 26, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the moisture sensor: Schritt 26, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the moisture sensor: Schritt 26, Bild 3 von 3
    • Squeeze the locking tabs on the moisture sensor connector.
    • Disconnect the connector.
  27. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the main board: Schritt 27, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the main board: Schritt 27, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the main board: Schritt 27, Bild 3 von 3
    • Label, photograph or make a sketch of the connector locations and of the main board bracket position on your machine.
    • Disconnect all of the connectors on the main board front half.
  28. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 28, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 28, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 28, Bild 3 von 3
    • Disconnect all the connectors from the rear half of the main board.
  29. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the main board from the main board bracket: Schritt 29, Bild 1 von 1
    • Remove the sheet metal screw that retains the main board to the main board bracket.
  30. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Separate the main board from the main board bracket: Schritt 30, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Separate the main board from the main board bracket: Schritt 30, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Separate the main board from the main board bracket: Schritt 30, Bild 3 von 3
    • Lift the rear corner of the main board nearest to the side walls of the chassis.
    • You want to release the locking tab on the side of the main board.
    • Slide the main board toward the front of the dryer to release the tabs securing it to the main board bracket.
  31. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the main board: Schritt 31, Bild 1 von 1
    • Remove the main board from the main board bracket.
  32. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the main board bracket: Schritt 32, Bild 1 von 1
    • Remove the sheet metal screw holding the main board bracket.
  33. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the wiring harness from the main board bracket: Schritt 33, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the wiring harness from the main board bracket: Schritt 33, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the wiring harness from the main board bracket: Schritt 33, Bild 3 von 3
    • Lift off the main board bracket from the chassis and turn it so the bottom is exposed.
    • Using long nose or slip joint pliers, pinch the locking wings of the harness retainer clamp.
    • Separate the harness from the main board bracket and remove the main board bracket.
  34. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the upper front bulkhead: Schritt 34, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the upper front bulkhead: Schritt 34, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the upper front bulkhead: Schritt 34, Bild 3 von 3
    • Remove the screws securing the upper front bulkhead to the front of the chassis.
    • Remove the sheet metal screws securing the top plastic portion to the upper front bulkhead.
  35. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the upper front bulkhead: Schritt 35, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the upper front bulkhead: Schritt 35, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the upper front bulkhead: Schritt 35, Bild 3 von 3
    • Remove the upper front bulkhead and set it aside.
  36. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Release the belt tension: Schritt 36, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Release the belt tension: Schritt 36, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Release the belt tension: Schritt 36, Bild 3 von 3
    • Take careful note of the belt path before proceeding.
    • Be careful during this procedure! The idler arm is under spring tension and may pinch you, or it could damage the belt switch if the arm is allowed to snap down.
    • Push the idler arm (the metal upside-down "L") up to relieve the tension on the drive belt.
    • Remove the belt from the motor pulley.
    • Gently lower the idler arm until it rests parallel to the dryer floor.
    • During reassembly, refer to your notes or the belt path link to rethread the drive belt.
  37. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the lower front bulkhead: Schritt 37, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the lower front bulkhead: Schritt 37, Bild 2 von 2
    • Remove the screws securing the lower front bulkhead.
  38. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lower front bulkhead: Schritt 38, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lower front bulkhead: Schritt 38, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the lower front bulkhead: Schritt 38, Bild 3 von 3
    • While supporting the drum, lift the lower front bulkhead off of the hooks on the chassis.
  39. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 39, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 39, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement: Schritt 39, Bild 3 von 3
    • Lower the bulkhead about 2 inches to free the drum rollers tucked under the drum.
    • While supporting the drum, remove the lower front bulkhead.
    • During reassembly, tilt the bulkhead to the right to get the rollers under the lip on the front of the drum. Once the drum is on the rollers, you can move the bulkhead to the upright position.
  40. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the drum: Schritt 40, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the drum: Schritt 40, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the drum: Schritt 40, Bild 3 von 3
    • Use the belt to lift the drum a few inches.
    • Swing the drum out of the front of the dryer.
    • Note which end of the drum faces the front.
    • If the belt is broken, stand in front of the drum and put your arms inside it. Lift it up and pull it through the front opening of the machine. Having someone to help you with this is a good idea.
    • Make sure you get your drum back on the rollers when you reinstall the lower front bulkhead. Take your time and don't force it.
  41. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Hi-limit thermostat/inlet thermistor information: Schritt 41, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Hi-limit thermostat/inlet thermistor information: Schritt 41, Bild 2 von 2
    • The following steps show how to test and replace the hi-limit thermostat/inlet thermistor.
  42. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the hi-limit thermostat/inlet thermistor: Schritt 42, Bild 1 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the hi-limit thermostat/inlet thermistor: Schritt 42, Bild 2 von 3 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the hi-limit thermostat/inlet thermistor: Schritt 42, Bild 3 von 3
    • Pull the spade connectors straight off to disconnect the hi-limit thermostat portion of the hi-limit thermostat/inlet thermistor.
    • Be sure to grip the connectors and not the wire when disconnecting.
  43. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Test the hi-limit thermostat: Schritt 43, Bild 1 von 1
    • If you do not need to test the hi-limit thermostat, skip this step.
    • This step requires a multimeter. If you aren't familiar with how to use one, here is a guide that will help you.
    • With the hi-limit thermostat disconnected, you can check it for continuity. It should show continuity (less than 1 Ω) at room temperature.
    • If it shows OL or anything above 1 Ω, replace it.
  44. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the inlet thermistor: Schritt 44, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Disconnect the inlet thermistor: Schritt 44, Bild 2 von 2
    • If your hi-limit thermostat does not have this thermistor, skip this step.
    • Free the inlet thermistor connector by lifting the black locking tab with a small flathead screwdriver or spudger.
    • The locking tab is fragile, so only lift it a small amount to free the connector. Make sure to grasp the connector, not the wires when disconnecting them.
    • Once freed, pull the connector straight out to disconnect the inlet thermistor.
  45. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Unfasten the hi-limit thermostat/ inlet thermistor: Schritt 45, Bild 1 von 1
    • Remove the sheet metal screws securing the hi-limit thermostat/ inlet thermistor.
  46. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the hi-limit thermostat/ inlet thermistor: Schritt 46, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Remove the hi-limit thermostat/ inlet thermistor: Schritt 46, Bild 2 von 2
    • Remove the unit by pulling it straight out from the mounting hole.
    • If your hi-limit thermostat does not have a thermistor attached, you may skip the next step.
    • Note the orientation for reassembly.
  47. Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Test the inlet thermistor: Schritt 47, Bild 1 von 2 Whirlpool Dryer Hi-Limit Thermostat/Inlet Thermistor Testing and Replacement, Test the inlet thermistor: Schritt 47, Bild 2 von 2
    • This step shows how to test the inlet thermistor. If you just need to replace the hi-limit thermostat or inlet thermistor, you can skip this step.
    • With the thermistor removed from the heater housing, test for resistance with the multimeter across the two small terminals.
    • The resistance values of this component vary. You may be able to locate a tech sheet booklet in the chassis of the dryer to find the value.
    • If the device shows outside the correct range, replace it.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30.338 Reputation
213 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.494 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 29
Letzte 30 Tage: 115
Insgesamt: 1,103
