Zum Hauptinhalt wechseln
Whirlpool Refrigerator - WRS588FIHB Control Board Replacement
Was du brauchst
  1. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the dispenser panels: Schritt 2, Bild 1 von 2 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the dispenser panels: Schritt 2, Bild 2 von 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: Schritt 3, Bild 1 von 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: Schritt 3, Bild 2 von 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: Schritt 3, Bild 3 von 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the control board: Schritt 4, Bild 1 von 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: Schritt 5, Bild 3 von 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: Schritt 6, Bild 1 von 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: Schritt 6, Bild 2 von 3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: Schritt 6, Bild 3 von 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the control board: Schritt 7, Bild 1 von 1
    • Remove the control board.
Abschluss
Matt Zieminski
38.264 Reputation
13 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.523 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 7
