Zum Hauptinhalt wechseln
Whirlpool Refrigerator Start Relay Assembly Replacement
Was du brauchst
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    Frag FixBot
    Kommentar hinzufügen
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: Schritt 2, Bild 3 von 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
    Frag FixBot
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: Schritt 3, Bild 1 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: Schritt 3, Bild 2 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: Schritt 3, Bild 3 von 3
    • Pull the rear panel off the chassis to remove it.
    Frag FixBot
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: Schritt 4, Bild 1 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: Schritt 4, Bild 2 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: Schritt 4, Bild 3 von 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
    Frag FixBot
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: Schritt 5, Bild 3 von 3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
    Frag FixBot
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: Schritt 6, Bild 1 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: Schritt 6, Bild 2 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: Schritt 6, Bild 3 von 3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the run capacitor, start relay, and overload relay.
    Frag FixBot
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: Schritt 7, Bild 1 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: Schritt 7, Bild 2 von 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: Schritt 7, Bild 3 von 3
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
5 weitere Personen haben diese Anleitung absolviert.
nicO
15.990 Reputation
89 Anleitungen geschrieben
3 Kommentare zur Anleitung
Is it universal part
dyannatorres@yahoo.com - Antwort Teilen
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO - Antwort Teilen
Last part is not clear about where to put multimeter probes for testing each component. It makes the whole exercise useless.
Shafeeq Qaiser - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 80
Letzte 30 Tage: 396
Insgesamt: 16,229
