Einleitung
If the joysticks on the YCCTEAM YCC-SW4001 are drifting or otherwise not functioning properly, follow this guide to replace them.
The joysticks are the users main form of navigation through a game or a menu. The caps are easy to replace, so it is common to customize the color or shape of the joystick.
One common problem is drifting, which happens after gradual wear and tear. This could be from decay of the joystick caps or the joystick module (the stick under the caps). If the problem lies in the joystick module, replacing this requires knowledge of soldering as well as access to a soldering kit.
Was du brauchst
Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
Remove the two joystick covers from the motherboard by gripping them and pulling them straight upward with moderate force.
Use tweezers to lift the battery connector directly up and out of its motherboard port.
Use a Phillips screwdriver to remove the three 7.5 mm screws that secure the motherboard.
Remove the player LEDs.
Grip the white rumble motor motherboard connections and pull them directly out of their ports.
To remove each joystick module, desolder the marked connections using a soldering iron and solder wick.
