Einleitung
If your Eufy Robovac G32 Pro's power and control buttons aren't working, then follow this guide to replace them. There are three main power and control buttons, a spot cleaning button, a recharge button, and an auto cleaning start/pause button. The power and control buttons could not be working due to something blocking the sensor, or the board itself is broken.
Was du brauchst
Make sure your device is turned off.
Flip the device upside down on a flat surface.
Press the clips at the bottom of the device that are indicated by the downward facing arrows.
Take off the rolling brush cover.
Orient the device so the underside is facing up.
Remove the eight 9.3 mm screws securing the bumper brackets using a Phillips #1 screwdriver.
Remove the bumper brackets.
Lift the bumper off of the device gently.
Use your fingers to disconnect the 8 pin connector.
Remove the dust collector by grabbing under the lip and pulling it out.
Remove the six 5.5 mm screws securing the button board with a Phillips #1 screwdriver.
Grab the 8 pin connector with your hands and firmly pull it away from the board.
Remove the board.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
