Zum Hauptinhalt wechseln
iRobot Roomba Edge-Sweeping Brush Replacement
Was du brauchst
  1. iRobot Roomba Edge-Sweeping Brush Replacement, Loosen the edge brush screw: Schritt 1, Bild 1 von 1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
    Frag FixBot
    Kommentar hinzufügen
  2. iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: Schritt 2, Bild 1 von 2 iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: Schritt 2, Bild 2 von 2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
    Frag FixBot
Abschluss
Tobias Isakeit
134.123 Reputation
189 Anleitungen geschrieben
Tobias Isakeit - Repairability Engineer Mitglied von Tobias Isakeit - Repairability Engineer
Business
1 Mitglied
1.161 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 118
Insgesamt: 3,110
