Einleitung
If your ionvac SmartClean V2 fails to power on, or the power button is loose, stuck, or broken, it may be a sign that the button needs to be replaced. In order to complete this process, you must first disassemble the top shell that houses the button. This guide will show you how to remove the power button without causing any damage.
This is a quick and easy replacement, and you will need a Phillips #2 (PH2) screwdriver and a Jimmy tool (or another prying tool) to complete it. Remember to remove and reinstall all parts gently.
Was du brauchst
Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
Remove the rims from your ionvac and set them aside.
Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
Flip the frame upside down so that the inside faces upwards.
Locate the 2 screws connecting the power button to the frame.
