Zum Hauptinhalt wechseln
Das HTC One X ist das erste Smartphone von HTC mit einem Quad-Core-Prozessor und wurde im April 2012 veröffentlicht.
"No Sim detected" problem
The Sim card detection suddenly stopped. Whatever service is put in, no SIM card detected.
What might be the reason?
What is the Fix?
Thanks,
Ravi
Ist dies eine gute Frage?
Bewertung 10
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
I found that my issue was that there is a piece of metal at the bottom of the SIM card slot that when you put it the sim it connects with a sensor that tells the phone a sim is inserted. But the issue is the metal cage does not cover the full sim area and the metal arm can dislodge at the bottom and doesn't connect. I had to take the back off and push the arm back in alignment to have it recognize the sim again.
Hope this helps,
War diese Antwort hilfreich?
Bewertung 5
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
Bewertung 2
I have this Problem after "NO" remedy finaly went to shop who change the Jacket which cost me a good amount
Bewertung 1
Hi,
I had the same problem and I've found a solution of that problem in youtube. Have a look it might help you as well.
https://www.youtube.com/watch?v=gfNUu4Dj...
Thanks
Bewertung 0
Geniiioooouuussssss!!!!! Thanks a lot!
Bewertung 0
1 Kommentar:
Which answer helped you?
von
SIM card in my phone but
No SIM card shows me
Please halp mee
Bewertung 0
Antwort hinzufügen
Ravi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 24,499
