Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
548 Fragen Alle anzeigen
Installing a HD in optical drive bay
I have an old iMac 20" (EMC 2133)
I'd be interested in removing the optical drive and replacing it with a small SSD to run OSX on. I know this can be done with on a Mini, but I found no info on whether or not this can be done at all on my iMac model.
Any info would be appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Replace it just like you would a normal hard drive. Here's how: iMac Intel 20" EMC 2133 und 2210 Festplatten-Austausch
UPDATE
Sorry, I missed that. Here's what to use: iMac & Mac mini Dual Drive Enclosure
iMac & Mac mini Dual Drive Enclosure Bild
Produkt
$19.99
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Good to see you back. +
von
Sure - I understand that the procedure to get to the ODD and HDD are similar.
Nevertheless, I am going to need a caddy of sorts to house the SSD where the SuperDrive used to be, or not? What sort of caddy might I need?
And, is the connection SATA or PATA for the ODD of a Mac A1224?
Thanks
von
It won't work. The early 2008 iMac used an ATA connector for the Superdrive... not a SATA one. Sorry...
Bewertung 2
I just took my 2007 20” iMac apart to do this with a caddy similar to the one recommended above and this won’t work because the connector, as noted by Lawson above, is different.
(optical drive is below, ssd caddy above).
Bewertung 1
1 Kommentar:
Yes, the top one is SATA. The bottom one is ATA 100, a much slower interface, which is what pre-2009 iMacs use in the dvd slot.
von
Hello Mayer, I just wanted to make sure that the "12.7 mm SATA Optical Bay SATA Hard Drive Enclosure"
works on the Early 2008 iMac. It only lists MacMinis as being compatible.
If it does, I would like to use it to install a SSD.
Thanks in advance.
Bewertung 0
2 Kommentare:
Just to be sure (none of the adapters are listed for iMac) I would contact iFixit directly and ask them. Here's where to do it: http://www.ifixit.com/Info/contact
von
I just sent them a message, thanks.
von
Did you ever get an answer if this would work?
Bewertung 0
Antwort hinzufügen
Valerio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 6,013
