Zum Hauptinhalt wechseln
The HP Pavilion dv9000 series was introduced in 2006.
Overheated Motherboard by reflowing videochip
I tried to re-flow the video-chip on the motherboard but i overdid it.
Now can i buy a new Mobo but the product number is different.
my mobo 461069-001
the one for sale 441534-001
Can i replace it with this?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi Eogon,
Not sure if you resolved your question or not, so I thought I would offer some input.
The easiest method of determining which motherboard you can use is as follows...
On the bottom of the computer or under the battery, you will find the product number. It should look very similar to "GJ156PA#ABA". Also take note of the serial number.
Take those numbers and go to the following web page... http://h20141.www2.hp.com/Hpparts/
Enter the product number into the corresponding field and press the enter key on your keyboard. If the system says that no match can be found, then try the serial number in the serial number field.
On the next page, you will have a couple drop downs. Look for the one(s) that say "PC Board" or "Main Board" and choose the appropriate one. The resulting page will give you the part number and if HP stocks it or if you'll need to contact a reseller.
Hope that helps
War diese Antwort hilfreich?
Bewertung 1
The 461069-001 is for a intel cpu and the 441534-001 is for amd.
Bewertung 0
1 Kommentar:
Thank you for this information.
Where can i find the information over what motherboard i can use?
von
Antwort hinzufügen
Ernst wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 4,754
