Single Beep No Boot. RAM issue?
The MacBook Air was was working perfectly fine when suddenly the screen froze and I had to do a force shutdown. After that when I tried to boot, I got a Single Beep with intervals of ~5 seconds. If I press and hold the power button, the light flashes continuously for 4 seconds and then it beeps.
The screen is blank and there is no processor or hard drive activity while it beeps.
I have tried the 'CMD+R+P' and press and hold 'D' boots without any success.
This is most likely a RAM issue but since the RAM is soldered on, I cannot reset it as most guides have mentioned.
This is what the motherboard looks like: http://imgur.com/a/ZYy1l#0
Any help would be really appreciated.
Thanks in advance!
Ist dies eine gute Frage?
5 Kommentare
Whatever happened with your computer? I am experiencing the same thing, and anticipating the worst.
von Will Z
Try to disconnect the battery if it is possible on the MacBook Air and press the power button for about 30 seconds with battery and power adapter being removed - this will reset all capacitors within the book and RAM is a kind of (very basically).
If this does not bring any success I think the RAM is bad.
Regards, Stone
von Stone
Hey all if it is beeping it's the ram.
Remove the main board
Use a heat gun to heat up the ram on the back and the front
Let the board cool
Done! Worked for me
von Corvin McLean
I've had this problem and searched high and low - and despite warnings by 'professionals' to throw the Macbook Air away - I took one long last approach to clearing what was probably a moisture contamination issue on the mother board - Simply remove the Main motherboard - then clean it carefully with a solvent using cotton bud swabs, then into the oven at 190deg C for 9 minutes - and hey presto it came back to life perfectly. Trust me this is scientific.
von NIck Justice
heat gun from both sides helped me as well!!! don't be afraid, I put the gun quite close (3cm/1inch) and kept it until I count to 10, then other side and repeat until I was able to hold the board on the edge. Nothing was melting and I didn't believe it would help, I was prepare to put the board on my shelf as decoration, but it really worked! I'm so happy (-:
von Michal Vymazal
