Zum Hauptinhalt wechseln
Modell A1297 Unibody; Anfang 2009, Mitte 2009, Mitte 2010, Anfang 2011 & Ende 2011
544 Fragen Alle anzeigen
Frage geschlossen
Why no guides for this?
I just purchased one of the last MacBook Pro 17", Unibody Late 2011 models with a 2.4Ghz i7 quad core. I was hoping to be able to get your help with replacing the hard drive, and the optical drive. Why no guides for this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
That is a bit odd that the guides haven't been completed for the newer models but I can tell you that the process will be almost identical to the MacBook Pro 17" Unibody Guide. The only differences I can think of is that the battery may be different (may have to remove in order to disconnect, requiring either a tri-wing or pentalobe driver) and the Airport card may be mounted just above the optical drive. Both of these are pretty straightforward when looking at them though.
The Airport card / carrier removal should be very similar to the process for the 15" MacBook Pro Early 2011
Hope that helps!
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 386
