Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
What is error -1
i recently got my phone changed to orange in colour both front and back.. getting it back i had to restore it. connected it to iTunes and attempted the restore but failed. once the loading bar under the apple icon on the iPhone was full while restoring, it came up as unable to restore. unknown error (-1). does anybody know how i can fix this and how it happened?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 11
3 Kommentare
I've tried but it still wont restore?
von
this happened due to baseband ic chip , i've got the same problem in last week. m still upset
von
1. To fix error 1, you can restore your PC to an earlier time when the PC has not get the error 1.
2. Use RecoveryTool.
How to Fix iPhone Error 1 While Restoring iPhone
von
Einen Kommentar hinzufügen
11 Antworten
Gewählte Lösung
-1 Error of Hardware failure . it actually comes when Baseband (IMEI) of the IPhone corrupted . you have no option rather than replacing the iphone or Change the logic board inside. if you are using the mac then connect the phone in recovery mode and go to system profiler and then go to usb then select the iphone .this will show the serial number there . if the serial number show ffffffffffffffff like this then change the phone . otherwise we can try to recover the iphone .
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
where do i find system profiler? also, is changing the logic board expensive?
von
yes it cost approx near to phone itself. so buy the new phone or visit the apple service centre to replace it . it will cost approx 200$ . if your are using mac then press the shift+command +u. then you see the utilites folder, open the system information . choose the usb inside then iphone . after selecting you will see the iphone information
von
Can I simply buy the bare motherboard and transfer over the old processor and all that good stuff? Would that be sufficient to fix the issue?
von
Error negative 1 can also be iOS system error at the boot level. This can simply be fixed with a restore to factory defaults.
von
How can I recover the phone?
von
I had this issue with iPhone 5c (-1)
Removed the shield below the sim reader and heated the Qualcomm chip, and it restored
Bewertung 2
@SIMRAN I've this information from my iPhone 5 from the usb
Apple Mobile Device (Recovery Mode):
Product ID: 0x1281
Vendor ID: 0x05ac (Apple Inc.)
Version: 0.00
Serial Number: CPID:8950 CPRV:20 CPFM:03 SCEP:10 BDID:02 ECID:0000032AB4084D29 IBFL:1B SRNM:[C34JW9CHDTWF]
Speed: Up to 480 Mb/sec
Manufacturer: Apple Inc.
Location ID: 0x26210000 / 5
Current Available (mA): 500
Current Required (mA): 500
Extra Operating Current (mA): 400
Is this fixable?
Got error 1 after i tried to update...
thx for your reply
Bewertung 1
try restoring it in dfu mode
Bewertung 0
error code 1 is a modification code, I have only seen this code when a phone has been jailbroke and not for hardware mods, but I have had some bad luck with color conversion kits, they look real good and I have done this to my I 4 but I have installed many that never worked right out of the box, I caution people on this Mod as the parts are generic and a slight risk with your money, Do I think the color Mod caused your problem ? I dont know, but I would reinstall the factory parts and see if that takes care of it.
Bewertung 0
Did you fix your error? I have come across the same error and would like to know how you fixed it.
Bewertung 0
1 Kommentar:
This is a Hardware problem. when you remove the shield of Bottom side under the Charging jack. This is actually a problem of supply to Baseband Chip or either baseband is faulty. Beside the baseband chip there is a Golden crystal ic who supply the power to baseband . main this could be the reason .
von
hi I am having same problem with my iphone4 caused due to changing the body colour but I am having the serial no. of my phone please help me to fix it thank you.....
Bewertung 0
1 Kommentar:
this is not the reason of issue . during changing the parts you done something wrong to logic board thats why it giving the error during restore. Take the Logic board out from the phone and connect the good battery and charging jack then try to restore the phone without any other thing . check out the error now . if same problem then it is a logic board issue otherwise something other part malfunctions .
von
no real solution for this problem i tried restore in dfu mode it works for some hours but the iphone again corrupted so the soultion is to change your board ....for this reason change your iphone is a better solution
Bewertung 0
Error -1 is a baseband issue. The board needs to be repaired. You can buy the new components but it's tricky to do without experience. It's best to replace the baseband power ic first. If not solved then replace the baseband ic. It can be done with a heat gun but you will need a dentist type pick to remove the resin around the ic. There are a few vids on YouTube showing how it's done.
Error 1 is different. I think Mitch rush is right. It only seems to happen to jail broken devices
Bewertung 0
I do have the same problem (error 1) on my iPhone 5s.
I just wanna ask. What could be the cause of this error? Do it have something to do with the interrupted update or over chargeing the unit? I thought error 1 is beseband problem to it is something to do with the hardware. Thanks
Bewertung 0
1 Kommentar:
heat up the baseband IC and restore. it will work
von
Bewertung 0
1 Kommentar:
5s error (-1).
I faced this problem once before as well, but got solved somehow.
Cant solve it anymore. Any suggestions?
von
Antwort hinzufügen
chantee hunt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 64,988
