I want to replace timing chain
need step by step iinstructions on replacing timing chain on 1993 buick century 2.2 4 cyl
Ist dies eine gute Frage?
melvin, see if this helps :-):"
2.2L Engine
Disconnect the negative battery cable.
Remove the timing chain front cover.
Rotate the crankshaft until the piston in No. 1 cylinder is at TDC on the compression stroke. The marks on the camshaft and crankshaft sprockets should be in alignment.
Loosen but do not remove, the timing chain tensioner nut.
Unbolt the camshaft sprocket bolt, then remove the sprocket and chain together. If the sprocket does not slide from the camshaft easily, a light blow with a soft mallet at the lower edge of the sprocket will dislodge it.
Use a puller such as J-22888 or equivalent and remove the crankshaft sprocket.
To install:
Install the crankshaft sprocket, using the installation tool J-5590 or equivalent.
Install the timing chain over the camshaft sprocket and then around the crankshaft sprocket. Make sure the marks on the two sprockets are in alignment.
Lubricate the thrust surface with Molykote® or it's equivalent.
Align the dowel in the camshaft with the dowel hole in the sprocket and then install the sprocket onto the camshaft. Use the mounting bolt to draw the sprocket onto the camshaft and then tighten to 77 ft. lbs. (105 Nm).
Lubricate the timing chain with clean engine oil. Tighten the bolts on the chain tensioner to 18 ft. lbs. (24 Nm).
Install the timing chain front cover.
Connect the negative battery cable.
Hope this helps, good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 2,403
1 Kommentar
melvin, just to make sure, you do have all the tools and have done this before? this is a major job:-)
von oldturkey03
