Zum Hauptinhalt wechseln
Das Samsung Galaxy S3 ist ein Smartphone mit Multitouch- und Drahtlosladefunktion, ist Eyetracking-fähig und hat einen vergrößerten Speicher.
459 Fragen Alle anzeigen
water damage no sound
Hi, i dropped my S3 i9300 in water, i opened it and let it dry for a day post that i cleaned all the connections and put it back together,, made certain all is connected nicely.
So the phone is working fine the touch is good, camera is good, i can send and receive sms, chat i can brows net,, etc
The problem is..
there is no audio on the mobile, i cannot listen to any music, no ringer, no sound, only vibration ..
i cannot make or receive call, the call goes through technically, no no audio,, so cant listen on talk..
Please help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
6 Kommentare
did you ever get an answer to this? i have the same problem
von
Me too! Someone HELP!!!
von
Same here man only with my samsjng s4
T
von
My Samsung 1612 dropped in water and it's sound system does not work.
von
My LG k 500 n dropped in water yesterday.
I'd put it in charge.
My sound system is not working.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi gill,
Here are some suggestions:
1. Does the phone work on headphones/earphones?
2. Is the flight mode switched on?
3. Have you tried the app SoundAbout?
However, since your phone experienced a water damage, there could still be water on the motherboard that causes this issue. I recommend taking the phone apart (using this guide). Now lay the motherboard into isopropyl alcohol (90%) for about 10 minutes, take it out of this "bath" and let it dry for a couple of days next to a warm source (air conditioning, for example). Put everything together again and then test it again.
Steffen
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
It's not a phone it's a tablet
von
Same thing happened to me. I poured a little isopropyl alcohol into the bottom two holes and now everything works fine. DON'T BE AFRAID. Alcohol does not conduct electricity!
Bewertung 0
2 Kommentare:
Hi there, this is a little late but can you give the exact steps of what you did?
von
Yes...please elaborate....did you have to some how get the ipa out afterwards?
von
Antwort hinzufügen
gill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 94
Insgesamt: 50,099
