Zum Hauptinhalt wechseln
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
14 Fragen Alle anzeigen
Frage geschlossen
What Supply Voltages and Currents Does It Need?
I want to run an AirPort Express off a battery power supply. The cells I will use have a nominal voltage of 3.2V.
Could I run this with a 5.1V 1A source AND a source with virtually unlimited current and a voltage that fluctuates between 3.1V and 3.4V?
(By the way, those were two separate supplies mentioned, separated by AND. Not sure if that was obvious. Thanks to iFixit's power supply replacement instructions, I know that the AirPort Express requires two separate voltages.)
Rather than answering the above question, you could tell me exactly what two voltages it needs and the maximum currents it will draw at each. That might be easier :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
This question was migrated from http://meta.ifixit.com/Answers.
von
What amperage does the airport base station require
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It runs at 3.3 volts. The guide is excellent on this, you may want to review it: AirPort Express A1264
War diese Antwort hilfreich?
Bewertung 2
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,798
