Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Chrysler
My 1999 Chrysler Sebring JXI will not turn over?
So, I recently bought my Sebring JXI. It's a V6, and I seem to be having issues with it starting. It will turn over, but not start. I found out that it was not creating a spark, so I replaced the spark plugs and wires. Still won't work, so I replaced the distributor cap and rotator. Still no spark. So, I tested the fuel pump. It's working just fine. Now I take it to a shop. They replace the entire distributor. It works GREAT. I was super pleased, but now (not even a week later) it is repeating the issue. I have no clue what it could be.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
Your vehicle uses an internal ignition coil with a dstributor all built into one assembly. Your vehicle uses a CMP Sensor or camshaft position sensor to tell the ignition coils when to fire. If that sensor is faulty then you get a no spark condition.
If the vehicle is out of time because of poor workmanship due to a mechanics own error then yes bring it back to the shop. Have the shop foreman supervise the diagnostic strategy that the mechanic uses. This ensures that your problem is fixed.
von
Is your problem fixed? Please tell me what was wrong. I have same car model and code errors left and right. first fixed the distributor, then the alternator, then fixed the crank position sensor, and now code erroring the dang distributor assembly again, Firestone repeated the distributor and now still is running craptastic... They are not sure what it is either. The code is still erroring the distributor assembly.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Sounds like a timing issue to me. Especially after a full distributor replacement. If I were you I would take your car back to the shop and have them reset your timing and ensure all of the bolts are secured down tightly.
It COULD possibly be a computer error, im not to much into Chrysler but I am sure they can see if your ECM is throwing codes.
Just ideas
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
no spark relates to the camshaft sensor, if its faulty it
signals the A D S relay which cuts off fuel and spark .
von
Check the timing belt , if u got one.
Bewertung 0
2 Kommentare:
Same thing here.. No spark, have new distributor, new crank sensor, wires, plugs, battery, have fuel pressure. Wtf. !&&*
von
No timing marks, if skipped couple teeth somehow would it prevent spark?
von
i have a 1999 sebring and i have a bad positive jump start post in my fuse box what can i do to fix it
Bewertung 0
Antwort hinzufügen
sarah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 44
Insgesamt: 4,766
