Zum Hauptinhalt wechseln
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
857 Fragen Alle anzeigen
Why does it blow white smoke out of exhaust?
14.5 Briggs and Stratton Murray riding mower was in storage. Model number: 287707
Turned it on, stepped on the gas and would stay on for only a few seconds. White smoke would then blow out from the exhaust. The next day i turned it on and would turn off when i stepped on the gas. Checked the air filter and had fuel and oil mixed. Filter was wet. What can i do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Juan Hernandez, depending on how long it has been in storage, You could easily have bad/old fuel. The reason for the white smoke is most likely the excessive burning of oil, mixed with water from humidity. The "turn off when i stepped on the gas" most likely caused by a bad mixture. Change the fuel, replace the fuel filter. Clean the carb and fuel bowl and replace your spark plug, then re-evaluate.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Juan Hernandez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 6,046
