Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
574 Fragen Alle anzeigen
Need help identifying broken parts
Hello everyone,
I have broken pixels on my laptop display. Would you help me identify what is broken please?
Based on the installation guides, I don't know if it's the "display assembly" or the "LVDS Display cable" that I should replace.
On the right hand of the Macbook you can see the problem I'm facing: http://sdrv.ms/Y7CLWX
I know that sometimes, when I pivot the screen the "dead pixels" are back to normal.
Your help would be appreciated :)
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
maximedelneuf, I think the key here is " when I pivot the screen the "dead pixels" are back to normal" I would suggest that you replace the LVDS cable. It may have a broken wire that is responsible for this problem. If nothing else, it is also cheaper than a new display. Follow this guide to repair the cable.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thanks for your reply
von
Antwort hinzufügen
Maxime wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 95
