Zum Hauptinhalt wechseln
Die Xbox 360 ist die zweite Spielekonsole der Firma Microsoft und erschien in Europa am 2. Dezember 2005.
428 Fragen Alle anzeigen
My xbox 360 (newer version) won't turn on?
I mean look, I plug it in and when I touch the power button it makes the beep turning on sound but it stays off. Same with the disk input. I don't use HDMI I use the vid 2 for the TV.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi, it might be that the cables are faulty. Can u see the xbox showing the green rings? An hdmi cable is not that costly now, so see if u can get one and test with hdmi. Write back on what u did. Good luck.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
It doesn't show any green rings, and I'll try to get an hdmi cable as soon as I can. I'll get back to you when I try it out
von
It didn't work with the cable so I had to go send it in for repairs. Apparently somehow it was wet on the inside? (sorry for the late answer)
von
Common issue with "no power" is a usb port has bent pin and grounding. Visually check your Xbox 360 USB ports. None of the center pins should be touching the casing or outer area.
Bewertung 1
1 Kommentar:
All USB Ports are fine, but I've noticed that after I plug in the power and disconnect it there is a delay in the power box.....anything about that?
von
Antwort hinzufügen
Johnny wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 4,394
