Zum Hauptinhalt wechseln
Der Advance SP kam als Nachfolger des Advance 2005 auf dem Markt. Er hat ein quadratisches Klappgehäuse.
163 Fragen Alle anzeigen
Games play right, blank white screen. Help?
So I recently dropped my GBA SP on the ground and for some reason the screen is just white whenever I turn it on. I can hear the game working and it seems like everything else works fine, it's just the screen is totally unresponsive. The GBA SP is the AGS model 001 (The one with only a front-light). I really want to fix this and i'd like to do it at home. Can you please find me a link to a how-to video or a step by step walkthrough?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Isaac, here are the guides. It is possible that your LCD broke, or that the connection came loose. Use the guides to open it up and check on the connection first.
War diese Antwort hilfreich?
Bewertung 2
Hi there! If you were able to fix the problem, please let me know what you did. I have a similar problem, only my screen is black, with colorful vertical lines. So, it doesn't seem the LCD isn't working, it would seem maybe the ribbon to the screen is detached etc.
Bewertung 1
I had the same problem and did what oldturkey03 said and it now works.
Bewertung 0
Mine is working but after startup it turns white and I need to fix it!
Bewertung 0
Antwort hinzufügen
Isaac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 70
Insgesamt: 18,965
