Zum Hauptinhalt wechseln
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
55 Fragen Alle anzeigen
Car is over heating
Car over heats, but not consistantly. It will go weeks without overheating, then overheat two days in a row. I have changed the thermostat and the coolant is full.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Have you had the radiator flushed (may need to do this more than once)? Either you have some junk blocking the core and/or hoses. Lastly, your pump is going or your core is in trouble.
War diese Antwort hilfreich?
Bewertung 0
If it is intermittent I would suspect the radiator. It doesn't take long to blow a head gasket if the engine over heats so it's best to find the fix before it gets really costly. Jack
Bewertung 0
Antwort hinzufügen
carey portell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,429
