Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
What hard drive should I buy for my iPod?
My iPod classics hard drive recently failed. I am looking into replacing to myself because its obviously cheaper and pretty easy. What I'm wondering is if I could buy a hard drive from a 4th generation classic and put it in my 5th generation. A hard drive for a 4th gen is much cheaper than one for a 5th gen and has more gbs too. The more help the better.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Lorenzo, that will not work. Those drives have different interfaces and are not compatible. You can get a 60 or 80GB pretty reasonable, and if nothing else, you might want to consider a conversion to flash memory
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
I ended up going with the straight forward solution and bought a 30GB Toshiba hard drive online. Wasn't the cheapest solution, but made the most sense to me.
von
But I'd love to try flash memory out in the future.
von
That is perfect. quickest and most logical solution is to stay with what you got. Good choice. Best of luck to you.
von
For 80 dollars you can replace with a 240gb hard drive. Which makes this the largest music storage device of all time.
Bewertung 0
The original drives were by toshiba if you want to replace like for like. You can't use a 4g drive though. I would go with Craig and get the 240gb!
Bewertung 0
Antwort hinzufügen
Lorenzo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 252
