Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
iPod stuck on hold
After replacing the battery in my ipod 5th generation 60gb my ipod was not coming off hold. I bought a replacement hold switch on eBay and after replacing this the ipod is still stuck on hold. Could this be the logic board?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hugo, the way I would proceed is by checking the flex first. Make sure it is properly seated and locked. Then check the switch on the flex itself, check to make sure that the switch is properly engaged between the two tabs of the slider. You can recheck this by keeping your iPod open while you try it out. If that still wont work, I would definitely try one more flex cable before replacing anything else. Hugo, if you place the iPod on Hold, and then disconnect the flex cable, the iPod will remain on Hold. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi,
I tried another hold switch cable, but no luck. So I guess I will go to replacing the logic board with I guess will solve any problems.
Thanks!
von
Check the wires that connect the hold switch to the logic board. If nothings wrong with the wires check the pins on the logic board. If this fails replace the logic board.
Bewertung 0
1 Kommentar:
Thanks Jacob, on the pins should I just look to see if they are misaligned at all?
What is strange is when I disconnect the hold switch wire from the logic board the iPod still remains on hold? Its a real shame if it is the logic board as apart from this the ipod was functioning well.
von
Antwort hinzufügen
Hugo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 192
