Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
265 Fragen Alle anzeigen
Type of glue appropriate for plastic and aluminum?
The clutch cover on my Macbook is loose. It's not bad by any means and certainly not critical, but it's a little wobbly and thus creaks whenever I place my hands on it.
Here's an iFixit pic of the area I'm talking about:
http://d3nevzfk7ii3be.cloudfront.net/igi...
I'd like to dab a tiny bit of adhesive on the clutch cover, but I'm not sure what type of glue is appropriate for the task. Any advice would be appreciated, thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A dab of epoxy compound (pick your poison there are many) worked in with a toothpick or plastic spatula along the edges would be my recommendation. Plain glue wont stick to itself with strength - but- epoxy is made for that purpose. Ensure that you mix equal amounts hardener and resin - maybe a small bit of glass fiber would help too (don't want to make it bulky but wiggling will reduce the life of the bond).
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Kim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 1,286
