Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
Can I replace my optical drive with anything cool?
My optical drive has been dead for about a year, now. I'm considering replacing it, but I'd like to know if there's anything else I can do with that space. I don't need any more hard drive space. I was considering just removing it to save weight and power, but I'm not sure its power consumption is that great while not in use. Is there anything else that would be cooler? Perhaps a gps device mounted to the inside?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Same issue, i already have one M.2 SSD and a sata SSD. I do not want hdd cuz its loud, but i also dont want to spend more ssd money since i have plenty free space. This is the best solution i found so far, a fan to cool down your laptop + a slot for ssd, wi-fi card, etc. https://www.ebay.com/itm/Laptop-Internal...
von
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
On Fastmac.com Store you can find a slot-In Blueray drive for your MBP:
http://fastmac.com/slim_bluray.php
Otherwise you there are other ideas for this free space:
- solder a USB Hub into it
- or a usb powered GPS or UMTS stick.
- or an unit to take the remote into it - with a slide in technique
- Buy an mediabay for a Dell notebook (ebay) and put a hdd into it the connector that must fit is properly an MOLEX connector.
thats from me at this point
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
If I ever do this, I will probably try to solder in a usb GPS device, and have it phone home all the time.
von
The catch with that FastMac Blu-ray drive (other than the price) is that it won't fit into a MacBook. That's a 12.7mm drive, and the MacBook will only take optical drives up to 9.5mm high. If you have a 17" machine, then that Blu-ray drive would work.
von
How would one go about soldering in a USB hub? This would mean additional USB ports/devices, correct?
von
Hilfreichste Antwort
With some work, you could turn the space into a storage area. Unfortunately, the iPhone is too thick to fit into that space. However, the iPod touch is thin enough to fit in the optical drive bay. You could make a slot to store an iPod touch inside your computer. If you really wanted to get fancy, you could add a dock connector inside the optical bay so you could dock your iPod internally.
Bewertung 8
2 Kommentare:
That would be awesome!
von
You could dock an iPhone 4 in there!
von
You can add a Blu-Ray drive :)
Bewertung 2
2 Kommentare:
Is there a Blu-ray drive that will fit in a MacBook? To fit in a MacBook It needs to be 9.7mm, and all the Blu-ray drives I know of are 12.5mm.
von
I agree with Luke, there are no blue-ray drives that would fit according to NewEgg.com
von
Add a Solid State Drive.
http://www.codinghorror.com/blog/archive...
Bewertung 2
2 Kommentare:
Fascinating, but expensive :(
von
Good write-up about putting a solid state drive in a MacBook Pro:
http://blog.iso50.com/2009/08/25/ssd-per...
von
Or, if you already have a solid state disk (as I have) and want to add a hard disk for more space (as I will) you can get yourself a optibay enclosure that fits into the superdrive's space and can hold a hdd.
I just wait for my optibay to arrive.
Bewertung 1
Is posible to put a cooling system in this space?
I want to reduce the macbook temperature, I'm most of the time in a Library watching educational videos on youtube.
And also running parallels .
And it makes the cpu to 77º , fans 6200 rpm so it turns too noisy .
For me would be perfect to replace the optical drive with a Fan or cooling system , capable to get the heat out through the slot that normally you insert the dvd. In a silent way of course.
It is posible or I'm just dreaming ?
Bewertung 1
1 Kommentar:
The sell little fans that are coolers, I was looking for one when I gad a gaming laptop.
von
I want to do what Fons wants but with a PC laptop.
Bewertung 0
Antwort hinzufügen
Sterling Hirsh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 15,786
