Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
Frage geschlossen
Battery sometimes fails to properly charge
I've had this computer for a couple years now, and it's still running strong. The battery still gives me 4-5 hours charge, which is fantastic. The only problem is that sometimes the battery refuses to charge when my laptop's plugged in and the battery still has a good amount of charge (somewhere between 90% and 50%). Also, if I'm charging the battery from a lower charge, it sometimes refuses to finish charge - it says "Finishing charge" (or something like that, I'm not looking at it right now). What do you guys suspect the problem is?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I read somewhere that this is a known problem with the logic board. My macbook 2007 suffers from the same problem.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
sounds strange - maybe the battery gives wrong data to the logicboard
did you try coconut battery to determine the original capacity vs. the current capacity
are you able to try a different battery - maybe it works normal with a different one (or not - that way you could rule out a battery problem)
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I haven't attempted to use another battery, but my sister has the same style MacBook, so I'll definitely give that a try when I get the chance.
von
I haven't gotten any resolution with this, but I don't have the problem anymore. Perhaps just cycling the battery several times / the passage of time / software updates fixed it. Either way, I'm upvoting this answer so that the question is no longer "unresolved".
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,148
