Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Frage geschlossen
iPhone turn off after successful repair
After replacing the dock connector, digitizer and battery in my Iphone 4s the phone booted up and worked perfectly. After making sure that everything was alright I started to put that back plate on and was having trouble getting it in the right spot it needed to be in to slide into place. After a couple minutes i decided to try using a little bit of force and pressed down on the backplate and the phone turned off and wont turn back on at all. Ive tried hard resetting it and taking out the battery and connecting it back in and i get no response. Does anybody have any ideas what might have happened?
Thanks a lot,
Bryan
Oh and FYI the phone encountered some water damage a while back
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare:
Water damage is a tricky thing. How bad was the water damage? I myself have fixed phones with water damage only to have them last weeks. I do have one still out there that is going strong after about a year though.
von
It was pretty bad but it was working fine for about a month up until about a week ago and now a new thing is going wrong everytime i fix something lol. I just dont get why it would turn off like that when it was working for a couple of hours after my repair job
von
Is it recognized in iTunes?
von
No itunes isnt recognizing it but it did as soon as the repair was done and was working. As soon as i pressed the back plate in with some force everything stopped working all together.
von
Check your flex cables for proper routing, make sure they are seated properly and ensure that none of the cables have a tear in it.
von
Einen Kommentar hinzufügen
1 Antwort
You might have damaged the logic board. I would disassemble and inspect it. Also you should reseat the cables such as for video.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 129
