Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
16 GB possible with OS X Mountain Lion or Mavericks?
Have seen 16GB upgrade kits for sale from Data Memory Systems as long as you are running Mac OS X "Mountain Lion' or the latest release 10.9 "Mavericks',
Even in the popular reference app MacTracker states this possibility, I'm curious if anyone has attempted this upgrade outside of Apples stated limits.
I'm already upgraded to 8GB, but remembering the iMac of the same time frame also running a Core 2, could handle 16GB mainly due to the extra space.
Now with larger memory modules available, I wonder if it's true that these machines could run twice the purposed limits?
Update
Dan, some limits are only seen by slower drives. The limit on my Mac is 3Gb/s thanks to the 7200 RPM drive I installed over the original drive which was held back by the slower rotational speed. A move to a SSD has been something I've thought about for a while but I enjoy the extra space by the Scorpio Black and it reports in OS X in the system profiler as 3Gb/s.
The noticeable change after swapping out from the original drive was a noticeable improvement in both Macbench and even running the system score in Windows 7 via Parallels. HDD I/O was the highest in the overall score second only to the matched pair of memory sticks installed getting me to 8GB.
Concerning the optical drive, I'd prefer to keep it in as some games I play on my system still have a CD/DVD check for the application to boot. While I do have a older USB DVD RW drive that I picked up on eBay. I'd rather not risk it as all the documentation is in Japanese. I bought it for a fraction of the cost of the Apple USB SuperDrive.
I have had my intentions of having this computer last me at least six years as my last Mac did rather well longer than I ever had expected. (A PowerBook G4 which still runs on its PATA limited 320GB internal HDD upgrade I performed as well as running its limit of 2GB of memory. Firing it up every so often reminds me how much the difference running on Intel hardware but also some nostalgic look and feel of the design that evolved into the first MBP.
Leopard does show it's age a bit especially on PPC and the 1.5Ghz single G4 it boasts but still eaten alive in general tasks by the original first generation white MacBook. That is until you fired up a game where the Intel GMA was demolished by having the old 128GB dedicated ATi Radeon 9700.
Back onto the topic at hand, instead of people telling me "It can't be done' by reading documentation by Apple and such, I'm curious of the brave souls who have actually tried doing such a thing by thinking outside the box instead of only reading what specs Apple has posted on my particular MacBook Pro.
The main reason I ask is I thought there would be more daring individuals who experiment with "older' systems just to see how far they can be pushed.
If only I could post pictures of my old "Yikes' PowerMac G4 which was pushed beyond all possible reasonable thought. Just think a old 233Mhz slug getting a real kick in the rear with dual 1Ghz G4 processors. That was only the beginning after being challenged by a PC die-hard saying to me that it was impossible to upgrade a Mac.
I certainly had proven him wrong. :-)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare
8 GB of RAM is really a lot of RAM. 16 GB would really be overkill on this machine. It would also drain your battery much faster and very few programs could even use it.
von
I agree with Mayer. 16Gb of RAM on a laptop is murder on battery life. Mavericks is a little more RAM hungry than other previous Mac OS'es, but if you are not running intensive apps I wouldn't bother with a 16GB upgrade. But, thats just our opinion. To answer your question; yes, most of apples limits aren't actually the actual limits. And yes, I can personally tell you that in previously owned machines I have Exceeded Apple's limits with the actual limits and I have never had any issues.
von
I too agree here with Mayer, most users will have a hard time pushing there system with just 8GB of RAM. With that said CAD, video or picture editing can push the system into needing more than 8 GB but that is working on highly complex CAD diagrams or very large vids or deep pixel pics. And, yes more memory will require more power which reflects into how long the battery will run the system.
von
The root issue is the CPU and its Interface logic chip. Intel introduced the original mobile Penryn & I/O logic with limited address line support (32) later versions of Penryn it was enlarged to 36 lines. Which is why this gets confusing on why a given model can't and anther can support 16 GB of RAM. Review Intels' documentation for your CPU & Support chip your system has.
von
I just did the upgrade, mid 2010 MB Pro. 4gb was a roadblock. thought about 8gb upgrade, but with the few extra $$ the 16gb came to pass.
now, I realize this is 3 years after the OP, BUT with browsers like FireFox being memory hogs... the 16gb has FINALLY stopped my MBP from locking up after routine browsing for 10 min.
I currently have 3 tabs open in FF and my activity monitor has 8.13gb used, and in the last hour, has not locked up yet!
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Actually ALL 2010 (Core 2 Duo) 13" macbooks (white) and Macbook Pros can run 16GB 1066 Ram. I have run it on both of them with no problem (actually I have installed and run 16GB on over 25 different 2010 13" Macbooks and Macbook Pros.)
Also as an update. with Mavericks installed, I upgraded and ran 16GB on a 2010 17" Macbook Pro (2.53Ghz i5 with nVidia GT330M 512MB) which were all previously software limited to only 8GB!!
War diese Antwort hilfreich?
Bewertung 2
8 Kommentare:
Yes, I too have gotten some (not all) MBP "13 systems updated with 16GB of RAM. The issue here is the Rev of the logic board your system has. Intel had two versions of the controller chip and the older unit did not have all of the address lines active. So if you have the older Penryn Core 2 Duo (which the majority of systems are) you can't go to 16GB. Apple didn't change the chip out until the last few months before they intro'ed the i5/i7 models.
von
Interesting! I did not know this... But every single one of the 13" macbook and Macbook Pros from 2010 that I have tried this on have all worked without a hitch.... Either I got insanely lucky or...?? is there possibly an update that fixed the problem and that is why all of mine worked?
von
Yes, there was also a EFI update to enable the upper address lines on the newest version of the controller chip (still have some that won't work past 8GB). Here's the Apple TN: EFI & SMC firmware updates for Intel-based Macs. Apple doesn't tell us the full details on what they fixed or changed in the EFI which adds to the confusion here.
von
ahh, well that muddy's it up nicely then! :)
von
Hi Nathanael,
I just wonder which RAM do you use to perform this :
because I have the same systems and it's definitively hard to find 1066Mhz 8Go CL7 RAM.
thank you.
von
3 weitere Kommentare anzeigen
Hilfreichste Antwort
Yes & No
First what is your exact model as you talk about having a Core 2 version Vs a i5 or i7 version of the A1278. Can you supply the last four digits of your serial number so we can be sure here.
The Core 2 series of systems are limited to 8 GB of RAM (2 - 4 GB modules). The newer i5/i7 series can run 16 GB of RAM (two - 8 GB modules). In either case you do want to make sure your EFI is at the latest. Follow this Apple TN EFI & SMC firmware updates for Intel-based Macs.
I do strongly recommend using a matched pair of modules as I've seen some very odd behavior when mixing vendors and speeds or sizes.
As for running Mavericks: Review Apples approved models listing TN OS X Mavericks: System Requirements to make sure your system can run it.
Bewertung 5
9 Kommentare:
Apples limits are often based on what technology is available when the system was designed. Memory & HD technology has improved in leaps & bounds, not only is size but also requiring equal or less power than the previous generation with much larger (and faster) devices. So when you look at upgrading things review the I/O standards & the CPU's to see if it can support the larger density (it often it can) as well as the power needs (or differences between what you have presently and what you are putting in). If it looks like it will work it often does. With that said the Core 2 Duo & its support chips does not have the address lines to support more than 8 GB of RAM.
von
So I am a bit confused to if it might work on my Mid 2010 MBP which has 2.66GHz i7
Model Name: MacBook Pro
Model Identifier: MacBookPro6,2
Processor Name: Intel Core i7
Processor Speed: 2.66 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 8 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: MBP61.0057.B11
SMC Version (system): 1.58f17
Serial No last part: MAAGZ
I did buy it Xmas 2010 but I had my motherboard replaced in about 2013 as there was a problem with it. Not usre if they then gave me a new one or a used one.
I woudl really like to run 16GB of memory on it as my applications need a lot of ram and I don't really like the new glossy screen finish of the new macs ;( (specially bought the matte screen)
von
@ Daisuke - Here is the EveryMac listing for your systems series: MacBookPro6,2. As you can see they have yours limited to 8 GB. You should first make sure your systems firmware is upto date then give it a try. You can't hurt the RAM by trying it (just be careful with the clips and use ESD precautions).
von
Daisuke, I was able to get 16GB in both a 15" and 17" 2010 macbook pro with OS X mavericks and later with all refi updates etc... One was running same i7 as yours, and another with the i5 cpu... that being said, I haven't really heard of anybody else doing it, mine ran great for a year before selling it and the other was an upgrade for a friend, who ended up going a different route because he also needed sata3...
von
So Nathanael, You actually upgraded a MacBook Pro "Core i5" 2.53 15" Mid-2010 to 16gb and got it to work? Which exact RAM make and model was it? Please help I am in Thailand in the jungle and desperate to get the correct ram cause it takes 60 days to ship here. my facebook is enrico santo abruzzo or drmacsf@GMAIL thanks Enrico
von
4 weitere Kommentare anzeigen
It still lives! The 13" MacBook Pro I had asked about so long ago it feels like. "LittleBigMac" is one heck of a soldier and still runs strong with my photo editing in Aperture and Photoshop.
I can proudly say that with the latest upgrade to this same MacBook Pro, it's doing an amazing job running with OS X El Capitan and The latest upgrade in question is a 1GB SSD so I can really benefit the most of what this five year old Mac has to offer. Similar PC's would have be replaced by now but with a new battery, the 16GB system RAM upgrade, and just good general maintenance, this has been the absolute best laptop I have ever owned.
While I am still waiting for the SSD to arrive, I have been backing up my files from my home folder since I wish to do a clean install from it's initial shipping OS version to boot and then perform a network install just to have a clutter free system directory as I have never had any failure requiring an OS repair, re-install.
Many balk at me still rocking an old Mac like mine but it's never actually failed me ever. Plus the removal of optical drives in current Macs is rather frustrating so some old games I will have to give up on unless I wish to carry a bus powered external Apple SuperDrive and find an adapter if I wish to continue the practical included original MagSafe connector and beauty of the 27" ACD that has been a fantastic monitor.
I wish more PC's would have adopted MiniDisplayPort as a standard for full AV I/O let alone ThunderBolt which seems even less likely. I love my monitor and I feel for any computer of any kind, the best part of your budget should be in the monitor. Sure it's no 4K or even 5K like the latest iMac models with retina displays.
I will invest in a new Mac soon enough once this one I have stops being useful entirely. I'm just amazed at the longevity of Apple hardware and just how some models simply happen to be the best around.
Bewertung 3
3 Kommentare:
The only other thing you may want to do is replace the Hard drive/IR cable to a new one from a 2012 model if you ever start getting beach balls.
von
Well I've got a mid-2010 15 inches with two 512gb SSDs and 8GB RAM... and i can only say this is the best computer I've ever had. Won't be replacing it in the near term, I go or it goes ;)
von
@pantulis This generation of MacBook Pros were truly great computers. The build quality has been exceptional, reliability has been outstanding. I kept my optical drive since it gets a lot of use and several games that I love still have the requirement of having the original game disc in the drive. I'm sure the added bonus of a second SSD is great and I won't fault anybody for making the change.
I love my little 13" beast even though a newer Mac or PC would shred mine to tiny bits. It's simple pride in ownership in a long lasting older Mac that's holding up well past it's expected usable "life".
I may not upgrade until my Mac is cold and dead, something I've rarely seen happen to a Mac itself. A insanely great Mac by any standard.
von
My system is the 2.4Ghz Penryn Core 2 Duo with the Nvidia 320m GPU. Not the latest and greatest but for my photo editing, using my Mac has been a most amazing tool with Aperture.
The model of mine is a stock unit (MC47LL/A) that I picked up at Best Buy and upgraded to it's current specs listed with my HDD and 8GB memory upgrade (Samsung matched originals from Data Memory Systems and has performed extremely well with a improvement overall in comparison to Mountain Lion but working in Photoshop and Aperture has slowed a bit as the apps have grown more complex and file sizes increase. Thanks to the 7200RPM HDD has helped a bit.
In all my Macs I have used matched pairs of memory modules as I am very well aware of the issues that running mixed modules can bring. I'm already running OS X Mavericks ever since public release and have had no problems (only a gripe ever since moving on to Lion and losing Front Row as I loved watching my content on my 27" ACD)
So the upgrades on my system I have not skimped out on with questionable quality components. As stated before when upgrading to 8GB of memory, both sets of modules were Samsung parts from the 4GB to the upgraded parts. After upgrading, I ran my AHT DVD to make sure my memory were good parts.
To make things clear, my machine is more than just a browsing or general use Mac, the real killer has been my GarageBand projects where the extra memory is a godsend along with working in high PPI documents in Illustrator and Photoshop.
I have no problem with my CPU and my Mac still looks like new, I'm just wondering if double the memory whilst running Mavericks will improve from my current specs to double the memory without running into the OS compressing my documents in RAM as it is.
Bewertung 0
1 Kommentar:
Sorry, your at the limit of your system with 8 GB for RAM (your system can't access the higher memory addresses). You may want to think about upgrading your HD to a hybrid drive or think about swapping out your optical drive to a 2nd drive carrier and putting in a SSD. The only rub here is the optical drive PATA port is slow Vs your SATA port so you'll need to think about which drive goes where. Maybe its time to get a newer system which can support more RAM (16GB) and has a faster HD I/O SATA III (6.0 Gb/s) Vs your current systems SATA I (1.5 Gb/s).
von
hi there i have macbook pro 15 inch mid 2010, is it possible to make it 16 gb ram?
Bewertung 0
Antwort hinzufügen
Brian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 17,567
