Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
Frage geschlossen
Ripped solder pad off while removing the battery
So i was trying to replace a broken battery and everything went perfect but when i tried to solder the new battery on i saw that the middle solder pad was gone so my question is do i need the middle one and if i do is there any way to reatache it to the motherboard?
thank you and sorry english isnt my first language.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
juraj, rest assured you are not the only one that this happens to. Check on here and read through this one. For the repair, there is an epoxy that could be used to rebuild solder pads. Something like this should work. Or you could try to repair the pads by soldering to the traces. Check on here for more information. Hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 228
