Zum Hauptinhalt wechseln
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
484 Fragen Alle anzeigen
Washer makes very loud noise during spin cycle
My washer makes a very loud noise during the spin cycle (it does not make the load noise during any other cycles). The load is balanced and the drum is not wobbling side to side.
I have the same problem, it’s the drum bearings and seal. The seal leaks and water gets in the bearings and destroys them, hold the outer drum then try to move the inner drum, if it moves at all it’s gone!!
I'm going to pull mine apart and goto an auto parts place to match them! If that doesn't work will try to find them by the old part number on each one, I have two bearings and one seal. Good luck!
Dan
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
6 Kommentare
I have this problem too and now just noticed that it is spitting grease out in splatter pattern on the floor. Is it hard to change the bearings?
von
Dan - thanks for information. My Kenmore Elite Oasis (model #110.27042602) has gotten much louder during the spin cycle. Seems to be spinning fast and gradually going from slower to faster spin. Clothes may be slightly more damp ... just much louder. Potential Clutch Assembly issue? Correct part #? Also saw comments on Drum bearing and Seal ... possibly issue ... way to test? Correct part #? Both of these DIY repairs for folks handy at DIY things? Instructions with parts? Or on the Repair Clinic web site? Due to balance issue, I replaced the suspension damper springs/rods 6/18 and took care of that issue. Thanks - Doug
von
If its slinging oil or grease im afraid a new one is your best route. What would be next?
von
Ours makes a loud siren like noise at start of cycle. Its LOUD AF
von
It's Dec 2022, my Kenmore Series 600 is making loud banging in I initial spin when first starting. Sounds like a "Jake brake" could this be the clutch problem described here?
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Dan,
If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
Please give us the model number of your machine and we'll get you to the correct parts. An auto parts place is not going to have what you need.
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
This is probably the part you need: http://www.repairclinic.com/PartDetail/C...
War diese Antwort hilfreich?
Bewertung 5
7 Kommentare:
Mine wasn't spinning unless u started it by hand. Then started making a very loud banging noise. Replaced the clutch and brake, spins great now but still makes banging noise.
von
My Kenmore is on spin making a loud grinding noise and doesnot spin, what is it?
von
When just had ours installed yesterday and it shakes the house when it's on spin!
von
Dan - thanks for information. Mine (Kenmore Elite Oasis model #110.27042602) has gotten much louder during spin cycle. Seems to be spinning fast ... clothes may be slightly more damp ... potential Clutch issue? I also saw comments about the Drum Bearing and Seal. Thoughts there? Way to test? I'm handy ... these repairs DIY type? Instructions with parts or on the Repair Clinic web site? Thanks - Doug doug.mcgill57@gmail.com
von
von
2 weitere Kommentare anzeigen
My 15 year old Kenmore Elite HE3t was making a knocking noise during the spin cycle. So I took the lower front panel off (three screws) and taped down the safety switch on the right (Idiots, please don’t do this). When I ran the machine and got the knocking sound during the spin cycle, I pushed (with a stick of wood) on the outer tub (which does not spin), and the knock went away completely. I didn’t have to push hard. I presume that there is backlash (looseness) in one of the tub supports, or perhaps the tub is hitting the frame somewhere. Whatever, it’s been stable for a number of years now. So to fix it, I put a small spring from the top of the left front damper to an existing hole in the cabinet front. That solved the problem. The spring keeps the backlash from banging. Been working fine for a month now. I didn’t even have to move the machine to fix it.
Bewertung 0
Bewertung 0
I changed the clutch. The noise has gotten progressively louder. Almost metal on metal. As it spins, every time the tub reaches the same point in the spin, is makes a louder noise. When it is off, I can spin the tub by hand and it spins freely with no noise or resistance. I do not think it is the tub bearing. Transmission?
thoughts??
Bewertung 0
1 Kommentar:
I've got this issue. I think it's the bearing(s). You could/would need bearings, tub seals and pinion seal (to the transmission). And a "special" kenmore bearing tool but I think Amazon has something good enough for $20 like "Beaquicy W10447783 Tub Bearing Installation & Removal Tool - Replacement for Ken-more Whirlpool Washer" . Those included kit bearings are probably not correct for your washer.
It's kinda big job which is why some advice says to buy a new outer tub with the bearing installed. Why do it the easy way?
von
Antwort hinzufügen
Dan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 112
Letzte 30 Tage: 664
Insgesamt: 123,535
