Zum Hauptinhalt wechseln
Der Advance SP kam als Nachfolger des Advance 2005 auf dem Markt. Er hat ein quadratisches Klappgehäuse.
163 Fragen Alle anzeigen
Why will my Gameboy Advanced SP will not charge or turn on?
I got a GBA SP from my friends and I tried turning it on but it would not turn on. I then plugged it in to the charger. It flashed orange really quickly and then would stop charging. (Note: My OTHER friend said that the battery swells up on those things and it looks like that might be the case but I don't know how to fix that either.) If someone could help me figure that out I would be pretty happy!
Ist dies eine gute Frage?
Bewertung 7
5 Kommentare:
Same thing for me, but the battery replacement didn't work
von
I've diagnosed the problem with mine, the wiring between the charging port and the battery is somehow broken.
von
Same problem
von
Do a bridge on the F2 fuse.
von
i have that same problem
von
Einen Kommentar hinzufügen
4 Antworten
Tommy the very first thing you want to do is to change your battery. Here is the guide for it. The battery is available at places like this. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Already did. No help
von
I think you should bye a new gameBoy Advanced SP
Bewertung 0
Bewertung 0
All you need is a new battery :)
Bewertung 0
Antwort hinzufügen
Tommy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 12,493
