stuck cd how do I take the cover off
CD won't come out when I eject. You can actually hear it trying. I can not figure how to take the cover off so I can try to get the CD out.
Rob
Ist dies eine gute Frage?
Rob
First restart holding down the mouse button, that failing try:
Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk should eject." If this fails then look at doing surgery.
War diese Antwort hilfreich?
There is a guide that allows you to remove the Mac mini upper case exposing the inside and gives instructions to remove the optical drive and hopefully give you access to your CD again. You can view the guide here Mac mini (PowerPC) optisches Laufwerk tauschen.
Or similarly, reboot while holding down the mouse clicker. Again, though, as Mayer said, "if this fails then look at doing surgery".
Note that opening a Mac Mini is quite a bit tricky the first time. But the paint scraper shim does work.
that don't respond to "normal" emergency eject commands I use double sticky tape.
If this answer is acceptable please remember to mark it.
Good Luck,
N
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 1,920
