Pamela, definitely a broken LCD. Thank you for posting an image. After the new information that you provided, it looks like the last 3 digits of your serial number are "WOH" which comes back as a 2.33 GHz Core 2 Duo (T7600)
Intro Date: October 24, 2006 Disc Date: June 5, 2007
Order No: MA610LL Model No: A1211 (EMC 2120)
Subfamily: Core 2 Duo/Late 2006 Model ID: MacBookPro2,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 120 GB (5400 RPM) Std Optical: 6X DL "SuperDrive"
not as a PowerBook G4 Aluminum 15" as previously listed. In that case there are two display back cases. One for AUO panel (Apple part number 922-7934) and one for Samsung/Chi Mei panel (Apple part number 922-7933). So make sure that you order the right LCD to fit your case. The LCD is available for around $60 used and about $130 new. Check on here for more options. Is it worth it? Depends what you are looking for. $60 is cheaper than a new Mac (or any other computer) and as long as it serves your purpose, I would replace it. Hope this helps, good luck places
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
A1211 actually comes back as a Apple MacBook Pro "Core 2 Duo" 2.33 15", not as a PowerBook G4 Aluminum 15" which is the device that was listed with your question. This will of course change everything:-) especially the price:) Can you please verify that you have a MacBook Pro not a PowerBook G4
von oldturkey03
