Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für Fahrzeuge der britischen Automobilmarke, die 1903 gegründet wurde.
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
Ist dies eine gute Frage?
Bewertung 2
6 Kommentare
What year is your Vauxhall?
von
It's a 2005 55 plate
von
Does that relay also control the reversing light?
von
any more my light do not work 1.9 vauxhall combo reg 04
von
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
That's a great help.
Many thanks.
Geoff
von
You are welcome, best of luck to you.
von
This was really helpful to me many thanks
von
Hello,
Thank you, this is super helpful, even now!
If you're able, do you have a replacement source for the info? I have the same issue with my indicators, and want to figure out what relay to buy...plus my wipers won't go max speed anymore, which I think is linked to one of these also in the rear fusebox. The manual I have doesn't explain any of them, sadly.
Many thanks in advance!
von
@larn what exact year, model etc. is your Vauxhall? Let's see what we can dig up :-)
von
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
Bewertung 0
Antwort hinzufügen
Geoff Heyes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 37
Letzte 30 Tage: 147
Insgesamt: 34,764
