Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
797 Fragen Alle anzeigen
Frage geschlossen
Only sync a few megabytes at a time before dying
I recently replaced my hard drive because of this problem. I narrowed it down to being able to sync for a small amount of data at a time, then disconnect from my computer. If I try to do more it will return write delays on my laptop and reboot and go into "must restore" message. If a let it sit for 30 min and perhaps less without doing anything else, I can reset it to come back up happy, and I can see all of the music I have successfully synced again.
Do you think I still have a hard drive problem, or is it the logic card. Battery status is fine will go down if I leave on and charge up if connected, and appears to have no affect on whether my syncs are successfull or not.
Thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
I noticed you never got an answer to this. Are you still having this problem?
von
Yes, I had actually given up on checking :) I just ordered a new logic board hopefully that will fix the problem. If not I guess I am collecting parts for future systems :(
Thanks!
von
Einen Kommentar hinzufügen
1 Antwort
If you try reseting the firmware it could solve your problem. If by dying you mean shuting down, it could be a problem with a connecting between the harddrive. It could be a faulty logic board though.
If its running out of power it might need a battery replacement.
Hope this helps!
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 815
