Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
Schematic diagram or Component list
I have a 5th generation ipod that has the no-sound issue, I have isolated it to the capacitor C860 on the logic board as when I press lighltly on it with a plastic probe, the sound works. I have tried resoldering the connections on the board in case of a dry joint, but this did not fix it. My next step would be to replace the capacitor, but I cannot find out what the value is of this surface mount.
Does anyone have circuit diagram or a component list for this device?
You can see it in the photo, it is one of the two capacitors, I assume they are the same value.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
David, I just measure both of those caps and it comes up to 14uF for both. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
David wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 39
Insgesamt: 3,955
