Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für viele Kameras aus der Coolpix-Reihe von Nikon.
703 Fragen Alle anzeigen
No SD card in Nikon Coolpix L810?
I took a picture with my camera - not realizing that I didn't have my SD card in. I do not have the cord to transfer photos onto the computer. Is there any way I can put the picture from the camera memory onto the SD card? Is there a transfer option for this on the camera? Worried because now the picture is just "stuck" on my camera :( Help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
Very Helpful! I didn't realize my card was out of my camera. I took several photos and then realized they weren't on the SD card and had no idea how to transfer within the camera. This was a great relief. Thanks to Nikon for thinking of this in their programming! Doug
von
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Yes, I had to find my disk since this was no help. Press the playback button. Then press the MENU button. Arrow down to see "Copy" and press ok. This will give you the option to copy from the camera to SD card or from the SD card to the camera.
War diese Antwort hilfreich?
Bewertung 30
13 Kommentare:
lifesaver...great tip !
von
Thank you! I didn't even think I could take a picture without the card inserted.
von
Thanks a lot........great help
von
a life saver
von
Wow, Thank you!!!
von
8 weitere Kommentare anzeigen
With SD card installed, click the Playback button (button with the play triangle). It will tell you No Images are Stored in Memory if your SD card is empty or will just show what's on the card. That's ok!! Click the Menu button while in playback mode. Select Copy, Select Camera to card, Choose either Selected images to chose what you want to copy over or All Images. That simple!!
Bewertung 14
10 Kommentare:
This was the answer that saved my bacon
von
Thanks, this saved me from having to dig through the owners manual. Remember to find "copy" you have to scroll to the second page of the menu
von
Not only were you the ONLY person to get it right your hot looking! thank you so much!
von
Thank you!!!
von
Could not xfer, as the "copy" option was grayed out, turned out to be a defective SD card.
von
5 weitere Kommentare anzeigen
Relax!
You can transfer your saved image from the internal memory to your SD card later if you forgot to install the SD card by copying. Refer to your manual or this PDF copy Nikon CoolPix L810. Note on table of contents xviii Copy (Copy Between Internal Memory and Memory Card).
Refer to your Reference Manual CD section: Binocular 42 on how to do it.
Bewertung 6
3 Kommentare:
I no longer have the manual so I dont know how to transfer onto the SD card
von
@karenpinckard - Karen did you snag the PDF version I posted in my answer (blue link)? It explains how.
von
I have a 9900 and when I press the menu button nothing happens maybe my camera isn't working properly. I took some great pics today I really don't want to lose them
von
From SDF
POSTED: DECEMBER 16, 2014 OPTIONS
Granted, you cannot see the internal memory pics witha card in, but, follow "SDF's" instructions above, and the internals will be transfered to your card in total.
Bewertung 4
3 Kommentare:
Oh my gosh, this saved the day! Thank you!
von
SDF,
I tried that but as soon as I insert my SD card I am unable to find the photos that I have taken on my camera without the SD card in. Therefore what you've said is impossible! Anyone else have any ideas?
von
You cannot see the internal pics with card in, however they will transfer if you follow the instructions above.
von
1. Insert SD card into camera
2. click menu (without worrying about where your images are - you get to select location in next step)
3. go down to copy, click on it
4. select "Camera to Card" option
5. select, "all images" or "selected images"
6. Done
Bewertung 2
I tried all of the suggested ways & none of them worked! Then I had an epiphany!(LOL..I wanted to use that word for the longest) Anyway, I took my SD card out of the camera/Favorited all of the pictures that I wanted to transfer from camera to SD card/Reinserted SD card/
Turned camera on/press Picture view mode/ press Menu/ Press Copy from Camera to SD card/ Select all & Bam! Done deal!
Hope this helps!
Bewertung 1
HOW do I get my Coolpix s4300 to copy directly to my card? It used to do this....HELP
Bewertung 0
Antwort hinzufügen
morgan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 41
Letzte 30 Tage: 140
Insgesamt: 27,498
