Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
My iPod will not turn on , why?
My iPod will not turn on , it doesn't matter if I plug it in to my I Mac or not I still get no response . I have not used the device for 9 months but it worked when I stopped using it . The iPod itself is in excellent condition by all appearances.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Have you looked in the dock? Check to make sure that the port is still intact and fine. If it is damaged, you will have to replace the main board.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
The dock is in like new condition , the port is intact and complete .
von
Trying plugging it in to a wall charger (the OEM charger, 2A output) and try a reset on the device (holding the power and home button down for ~7 seconds).
von
Tom Lloyd, it is possible that your battery has been discharged below the threshold for it to be recharged. Sometimes a AC adapter can wake it up and charge it since it applies higher amperage than the computers USB port. If that does not work, I'd start off with a new battery and then re-evaluate. Hope this helps, good luck
Bewertung 0
Antwort hinzufügen
Tom Lloyd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 127
