Zum Hauptinhalt wechseln
Modelle A1237 oder A1304 / 1,6, 1,8, 1,86, oder 2,13 GHz Core 2 Duo Prozessor
313 Fragen Alle anzeigen
MacBook air battery 0%
Hi,
I'm having a weird issue here with the macbook air. First I thought the battery was dead so I purchased a new one. After replacing it: no charging, the magsafe light green, 0% on the battery icon. If I unplug the adapter -> sleep mode. I plug back the adapter, it wakes up but still 0% forever...
I tried (without success) pram and smc reset.
I also opened the rear case, plugged the adapter, power on, disconnect the battery while still powered, reconnect the battery and tada! Displaying 88% battery, everything seems normal, no sleep mode if I unplug the adapter, I thought the problem was solved. But if I shutdown and unplug/replug the adapter, I'm having the 0% battery issue again.
I cannot start the macbook without the magsafe adapter plugged. But I found another "trick": I plug the adapter, press the power button and unplug immediately the adapter. It boots, displaying 0% but still without going to sleep mode.
What the ****'s going on?
EDIT
Problem solved. I did the trick with unplug/replug while still powered and let it charge a whole day. Then everything came back normal.
I'm not a specialist but it sounds like something needed to "charge" apart from the battery.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
Hi jpfroud, thanks for the EDIT on your message. I have the same issue unfortunately and no forum out there has been helpful. However you seem to have done something but I can't seem to understand your trick. Could you detail it a bit more? That would great if you could !
Thanks in advance
Damien
von
@Damien Busson
Sorry, can’t remember, it’s too old
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
RUN AHT and see what it says.
My vote is for a bad SMC chip. If so, this would not be a beginner DIY project. If you have lots of experience with soldering small electronic or computer components your qualified, if not - this is not the place to start.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
von
Antwort hinzufügen
jpfroud wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 3,178
