Zum Hauptinhalt wechseln
Modelle A1237 oder A1304 / 1,6, 1,8, 1,86, oder 2,13 GHz Core 2 Duo Prozessor
312 Fragen Alle anzeigen
Pinouts for the isight / LVDS cable?
I was replacing an LCD on a Macbook Air, 2008, model A1237 and severed the cable leading to the isight camera and ambient light sensor up top. I've been looking around for replacements, but the cheapest I have found was $100!
Does anyone know the pinout to the isight camera, part # 820-2185-A, or where to get the pinout from? These camera seems to be regular USB and I'd like to test the camera out on a USB port and see if it even works before I go any further.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Edward, it would really help if you post some images with your question. It is always good if we can see what you see. this is the pinout I1 And 2 are unused.
Pin 3 (light blue, white conductor): USB D+
Pin 4 (light blue, purple conductor): USB D-
Pin 5/6 (orange): USB VCC (+5VDC)
Pin 7/8 (orange): USB GND
Also, take a look on here and see if that helps.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Edward wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 1,217
