Does replacing the charging port require soldering?
Does replacing the charging port require soldering? If it does, where can I get soldering tools?
Ist dies eine gute Frage?
Yes. You will probably need a micro-soldering iron. Check with an electronics store. You probably need a good amount of experience in soldering as well.
War diese Antwort hilfreich?
You should probably purchase a new motherboard since it is soldered on. It's pretty simple to replace
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 227
