Zum Hauptinhalt wechseln
Modell A1418 / Ende 2012 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
Change Front Glass Panel
Hello, i have broken the Front Glass from my iMac. Not the LCD. The LCD is ok.
Can i change only the Glas? It is possible to take off the LCD from the old Glas and make it on the new Glas?
And where can i buy the Glas?
Thank you very much.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
What is the right Glas Panel for my iMac 2012 Late. It is the 13,1 iMac. EMC 2544.
Thank you.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hans, I do not share the opinion on the ability to replace the glass by a DIY'er with my colleague. "To save space and eliminate the gap between the glass and the pixels, Apple opted to fuse the front glass and the LCD. This means that if you want to replace one, you'll have to replace both." and "cutting open the display destroys the foam adhesive securing it shut. Putting things back together will require peeling off and replacing all of the original adhesive, which will be a major pain for repairers." So is it possible? Certainly by people that have the right equipment and plenty of experience. If the ifixit team with all their resources and experiences in teardown have problems with this, I am convinced that the occasional fixer will have great trouble doing it. Just because the part is available does not mean that it is a task we can do. I'd suggest to replace the complete assembly. Part number for the assembly is 661-7109
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
I have the same model and the same problem (cracked glass, LCD fine). I had seen several guides showing replacement glass installation good for "2009 to 2012" 21.5 inch imacs that looked pretty straightforward. I was close to buying the glass and suction cup combo (assuming I'd only have magnets to contend with), but it sounds like that simple approach won't work for this model.
Am I correct in inferring that the procedure described at iMac Intel 21.5" EMC 2544 Display austauschen is the appropriate one? Why doesn't ifixit offer the replacement display/glass assembly?
von
You'll need to cut the foam tape that glues the cover glass to the LCD panel without damaging the LCD and cutting your self in the process. Even our replacement didn't hold up well and was dirty afterwards (we ended up replacing both with new display assemblies). The next problem is locating the cover glass. I don't know of any source to get the glass alone any more, now that there are spares available (full assemblies). I wouldn't waste the time or risk getting hurt here. Just get the complete display assembly. The Apple P/N is: 661-7109 - Display Assembly. Heres one source: PowerBookMedic
von
Thank you for your answer. It is not good but what happens?
Are there only Displays from LG or can i get a Display from Samsung for this iMac?
Is this the right? It is so cheap. It is Okay?
http://www.elecok.com/de/lm215wf3-sdd1-l...
Bewertung 1
Antwort hinzufügen
Hans wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 65
Insgesamt: 16,266
