Zum Hauptinhalt wechseln
2,3GHz, 2,6GHz oder 2,7GHz Quadcore Intel Core i7 Prozessor (Turbo Boost bis zu 3,7GHz) mit 6MB geteiltem L3 Cache.
561 Fragen Alle anzeigen
Stripped heatsink T5 screw! What to do?
I was following the "remove heatsink" guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torx screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
I tried with the two way you proposed but nothing... to be honest i'm stuck on the pentalobe now, i can't open the bottom case thanks to that screw!! my pentalobe screwdriver make a hole in the rubber band so it becomes useless... i don't know what to do! I think i will use a dremel to cut to brake the pentalobe screw and then when i'm in i will make a cut on the torx one to use a cut screwdriver.
Again sorry for my bad english :)
von
with an hammer?!? but i destroy my pc doing this!! :O
von
Purchase a screw extractor bit. I had the SAME problem on a Mac and had to resolve it this way. The cost is under $10 and a little effort on your part.
von
@Shaggot96 Try nipping off the sharp tip of an exacto knife. Put in stripped hole and turn. If it slips trim a bit more of the exacto blade. It worked for me!!! Cool.
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
I had the exact same thing happen to me on a Mac. I used a screw extractor (about $5 from a local tool store). It worked great.
I hate those darn T5's and smaller screws.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Hey bro, what mm screw extractor did u use?
von
DId you ever find out the extractor size?
von
I don't remember the exact size but I bought a 3 pack of 3 different sizes. The small was only slightly larger than the T5. The bit is tapered so it fit the screw hole.
von
Hilfreichste Antwort
Use a 1.3mm flat head bit. Might have to give a small amount of force but it worked for me.
Bewertung 2
2 Kommentare:
I had to use a Dremel to get the last three T5 screws out, file it down until you can use a flathead screwdriver.
von
Yes thank you! had same issue, small flat head did the trick Now where to get replacement 3.5mm Torx 5 screw ...
von
First try a different bit of the same size as your T5 bit is most likely stripped. If that does not work, this is the trick I sometimes use: take a rubber band and put it over the screw, then use a marker to indicate where the screw is under the band. Put the T5 bit into the marked off area and try to loosen the screw.
Bewertung 0
1 Kommentar:
Try to put a small amount of superglue on the end of the screwdriver and carefully insert it into the screwhead. Allow it to sit for about 1 hour and then try to remove the screw.
von
First get a flat head screwdriver and give it a couple of taps with a hammer and see if you can undo it that way
If you are going to use the dremel just use it to cut a small grove in the head for a flat screwdriver instead of breaking the screw with it
Bewertung 0
1 Kommentar:
A hammer on a T5 screw??? Yikes.
von
I hate Apple. They have this garbage hardware dressed up in their software. I tried taking the screws out to replace the battery and they ALL stripped and now its garbage. Can't change the battery. And for the record, I am not some nit-wit that can't handle a screwdriver of any kind, I work on computers all the time. But this macbook pro t5 screws really screwed me. Bought a new SSD and RAM which where both easy to replace and then this battery screws me. Garbage. Garbage. Garbage. I will never purchase another Apple product. I lie, I'll buy some Apple stuff. I got wrapped up in my emotions. Still though, cheap a__ __ T5 screws. My lenovo has better quality screws on it.
Bewertung 0
Antwort hinzufügen
Shaggot96 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 101
Insgesamt: 17,949
