Why is my hard drive not being recognized?
It won't boot. The hard drive is not recognized in Disk Utility or in a fresh install. I took out the hdd and plugged it in another computer and it is fine. The optical drive works fine, so I doubt it's the logic board. I think it's just the SATA power/data cable. I heard that it could potentially be fixed by putting some tape in between the drive and the cable to force the connections closer together. I will try that tonight and report back. If it's not the cable then I believe it's the logic board. I'm not interested in spending $600 on a new board, but I would be willing to remove the optical drive and use the adapter that allows for a second HDD to be installed there. So I guess I'm asking if anyone has any other ideas, but also I want to make sure that if I replaced the optical drive with my HDD that I could use that as my only drive. Everything previously says that it is meant to be used for expanded storage, but I want to confirm that it can be the boot drive as well. Thanks!
Ist dies eine gute Frage?
1 Kommentar
The tape didn't do anything for me. Didn't show up in Drive Utility, or during fresh install.
von HoratioDUKEz
