How do I change the brake caliper.
What is the procedure for changing the left, front brake caliper?
Ist dies eine gute Frage?
jfcuoco, from the repair manual:"
REMOVAL
1. REMOVE FRONT WHEEL
Torque: 103 N·m (1.050 kgf·cm, 76 ft·lbf)
2. DISCONNECT FLEXIBLE HOSE
(a) Remove the union bolt and 2 gaskets from the caliper, then disconnect the flexible hose from the caliper.
Torque: 29 N·m (300 kgf·cm, 21 ft·lbf)
HINT:
At the time of installation, please refer to the following item.
Install the flexible hose lock securely in the lock hole in the caliper.
(b) Use a container to catch the brake fluid as it drains out.
3. REMOVE CALIPER
(a) 5S–FE engine:
Hold the sliding pin and loosen the 2 installation bolts, and remove the installation bolts.
(b) 1MZ–FE engine:
Remove the 2 installation bolts.
Torque: 34 N·m (350 kgf·cm, 25 ft·lbf)
4. 5S–FE engine:
REMOVE 2 ANTI–SQUEAL SPRINGS
5. REMOVE 2 BRAKE PADS WITH ANTI–SQUEAL SHIMS
6. 1MZ–FE engine:
REMOVE 2 PAD SUPPORT PLATES
7. 5S–FE engine:
REMOVE 4 PAD SUPPORT PLATES
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 4,070
